[gdal-dev] Strange reset OGR_INTERLEAVED_READING when using Python bindings to read OSM PBF file
Sean Gillies
sean at mapbox.com
Wed Apr 2 11:56:10 PDT 2014
On 4/2/14, 12:29 PM, Even Rouault wrote:
> Le mardi 01 avril 2014 19:26:09, Dražen Odobašić a écrit :
>> Hi all,
>> I've been successfully reading OSM PBF files using GDAL Python bindings,
>> even files larger than 5Gb. I did have to use OGR_INTERLEAVED_READING=YES
>> and OSM_USE_CUSTOM_INDEXING=NO, but eventually OSM PBF is read and I can
>> extract data.
> Generally, you shouldn't have to mess with OSM_USE_CUSTOM_INDEXING.
> As far as OGR_INTERLEAVED_READING=YES is concerned, it is not sufficient to
> define the environmenent variable. I invite you to read again "Interleaved
> reading" in http://gdal.org/ogr/drv_osm.html. The sample C++ code (ported to
> Python) must be used *exactly*. I really mean it. That's what ogr2ogr does
> with OSM data.
Even,
Related question: are there cases where local configuration options are
not sufficient and environment variables must be used instead? Can we
(should we?) always rely on the configuration options set in a program?
Sean Gillies
sean at mapbox.com
