[gdal-dev] Strange reset OGR_INTERLEAVED_READING when using Python bindings to read OSM PBF file
Dražen Odobašić dodobasic at gmail.com
Wed Apr 2 12:21:14 PDT 2014
On 02.04.2014 20:29, Even Rouault wrote:
> Le mardi 01 avril 2014 19:26:09, Dražen Odobašić a écrit :
>> Hi all,
>> I've been successfully reading OSM PBF files using GDAL Python bindings,
>> even files larger than 5Gb. I did have to use OGR_INTERLEAVED_READING=YES
>> and OSM_USE_CUSTOM_INDEXING=NO, but eventually OSM PBF is read and I can
>> extract data.
> Generally, you shouldn't have to mess with OSM_USE_CUSTOM_INDEXING.
> As far as OGR_INTERLEAVED_READING=YES is concerned, it is not sufficient to
> define the environmenent variable. I invite you to read again "Interleaved
> reading" in http://gdal.org/ogr/drv_osm.html. The sample C++ code (ported to
> Python) must be used *exactly*.  I really mean it. That's what ogr2ogr does
> with OSM data.
Hi Even,
this is the Python code that implements interleaved reading, which is more or
less copied from the c++ example in the docs:
# prepare for the layer/feature iteration
nLayerCount = ds.GetLayerCount()
thereIsDataInLayer = True
while thereIsDataInLayer:
    thereIsDataInLayer = False
    # read data from layers using OGR_INTERLEAVED_READING method
    for iLayer in xrange(nLayerCount):
        lyr = ds.GetLayer(iLayer)
        # read next Feature
        feat = lyr.GetNextFeature()
        while(feat is not None):
            # continue reading features from this layer
            # do something with the feature
            # save_feature(feat)
            # force feature removal - required for INTERLEAVED_READING
            feat.Destroy()
            # get the next feature
I had no issues when reading large PBF files using this method. For the large
files, without OSM_USE_CUSTOM_INDEXING=NO I got lots of "Cannot read node ..."
error messages, and I'm not sure why. Basically I stumbled onto
OSM_USE_CUSTOM_INDEXING=NO which seems to help. However, in this case custom
indexing has no effect, script still fails to extract data.
Is there anything else I could try ?
Dražen
