[gdal-dev] [gdal 1.10] ogr2ogr ora-04043 object does not exist with spatial views in another schema of the connected user
SIMON Nicolas
nicolas.simon at spw.wallonie.be
Thu Apr 3 07:52:19 PDT 2014
Rémy,
One way to overcome delay is to add view name (or table name) in the command line.
Doing so will prevent you for scanning tables in the DB.
ogrinfo OCI:USR/PWD at INSTANCE:V_AGRI_EXPLOITATION
Nicolas
De : gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Rémy GOURRAT
Envoyé : jeudi 3 avril 2014 12:42
À : gdal-dev at lists.osgeo.org
Objet : [gdal-dev] [gdal 1.10] ogr2ogr ora-04043 object does not exist with spatial views in another schema of the connected user
my Oracle user connected had the "SELECT ANY TABLE" privilege so when I execute ogr2ogr to generate shp,
before to write the shape, ogr2ogr try to describe spatial View and table in each schema.
It's very long to generate a small shape because for each spatial view of another schema of the connected user
I have this message "ERROR 1: ORA-04043: object <the schema name>.<the spatial view name> does not exist
in OCIDescribeAny", we have a lot of spatial views in different schemas...
but It seems that I have a issue with the views of another schemas,
not tables and not views of the current schema (connected user).
Does I forget a privilege on my Oracle User ? a describe privilege that I don't know ?
Is there a switch to force ogr2ogr to use USER_SDO_GEOM_METADATA ?
When i drop the "SELECT ANY TABLE" to the Oracle User,
I have not this message and it's fast again.
Debug On, first I see that ogr2ogr list every table and every view with this request, (I put interline to optimize lisibility)
OCI: Userid=****, Password=****, Database=****
OCI: Prepare(ALTER SESSION SET NLS_DATE_FORMAT='YYYY/MM/DD' NLS_TIME_FORMAT='HH24:MI:SS' NLS_TIME_TZ_FORMAT='HH24:MI:SS TZHTZM' NLS_TIMESTAMP_FORMAT='YYYY/MM/DD HH24:MI:SS' NLS_TIMESTAMP_TZ_FORMAT='YYYY/MM/DD HH24:MI:SS TZHTZM')
OCI: Prepare(SELECT TABLE_NAME, OWNER FROM ALL_SDO_GEOM_METADATA)
ERROR 1: ORA-04043: object ORA_URBA.V_AGRI_EXPLOITATION does not exist in OCIDescribeAny
OCI: Prepare(SELECT COUNT(*) FROM ALL_SDO_GEOM_METADATA u, TABLE(u.diminfo) t WHERE u.table_name = 'V_AGRI_EXPLOITATION' AND u.column_name = 'GEOMETRY')
OCI: Prepare(SELECT SRID FROM ALL_SDO_GEOM_METADATA WHERE TABLE_NAME = UPPER('V_AGRI_EXPLOITATION') AND COLUMN_NAME = UPPER('GEOMETRY') AND OWNER = 'ORA_URBA')
ERROR 1: ORA-04043: object ORA_URBA.V_AGRI_EXPLOITATION_EXPLOITANT does not exist in OCIDescribeAny
OCI: Prepare(SELECT COUNT(*) FROM ALL_SDO_GEOM_METADATA u, TABLE(u.diminfo) t WHERE u.table_name = 'V_AGRI_EXPLOITATION_EXPLOITANT' AND u.column_name = 'GEOMETRY')
OCI: Prepare(SELECT SRID FROM ALL_SDO_GEOM_METADATA WHERE TABLE_NAME = UPPER('V_AGRI_EXPLOITATION_EXPLOITANT') AND COLUMN_NAME = UPPER('GEOMETRY') AND OWNER = 'ORA_URBA')
ERROR 1: ORA-04043: object ORA_URBA.V_AGRI_EXPLOITATION_PERIMETRE does not exist in OCIDescribeAny
OCI: Prepare(SELECT COUNT(*) FROM ALL_SDO_GEOM_METADATA u, TABLE(u.diminfo) t WHERE u.table_name = 'V_AGRI_EXPLOITATION_PERIMETRE' AND u.column_name = 'GEOMETRY')
OCI: Prepare(SELECT SRID FROM ALL_SDO_GEOM_METADATA WHERE TABLE_NAME = UPPER('V_AGRI_EXPLOITATION_PERIMETRE') AND COLUMN_NAME = UPPER('GEOMETRY') AND OWNER = 'ORA_URBA')
ERROR 1: ORA-04043: object ORA_URBA.V_AGRI_PAC_ILOT does not exist in OCIDescribeAny
Thanks for your help
Rémy Gourrat
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140403/42c797ce/attachment.html>
