[gdal-dev] Vagrant developement environment
Even Rouault even.rouault at mines-paris.org
Sun Apr 6 11:24:20 PDT 2014
Le dimanche 06 avril 2014 18:39:42, Ivan Lucena a écrit :
> Hi Even,
> I tried that out but got stuck on that error:
> $ vagrant up
> Bringing machine 'default' up with 'virtualbox' provider...
> ==> default: Clearing any previously set forwarded ports...
> ==> default: Clearing any previously set network interfaces...
> ==> default: Preparing network interfaces based on configuration...
>     default: Adapter 1: nat
> ==> default: Forwarding ports...
>     default: 80 => 8080 (adapter 1)
>     default: 22 => 2222 (adapter 1)
> ==> default: Running 'pre-boot' VM customizations...
> ==> default: Booting VM...
> ==> default: Waiting for machine to boot. This may take a few minutes...
>     default: SSH address: 127.0.0.1:2222
>     default: SSH username: vagrant
>     default: SSH auth method: private key
>     default: Warning: Connection refused. Retrying...
> The guest machine entered an invalid state while waiting for it
> to boot. Valid states are 'starting, running'. The machine is in the
> 'aborted' state. Please verify everything is configured
> properly and try again.
> If the provider you're using has a GUI that comes with it,
> it is often helpful to open that and watch the machine, since the
> GUI often has more helpful error messages than Vagrant can retrieve.
> For example, if you're using VirtualBox, run `vagrant up` while the
> VirtualBox GUI is open.
> I tried to load using the VirtualBox GUI but it didn't helped much
> showing the message "Driver Kernel not installed (rc=-1908)" and
> "NS_ERROR_FAILURE".
> Do you have any clue? My host is OSX 10.9 and VirtualBox is 4.3.8.
The error messages seems to indicate this is an issue with your VirtualBox
setup. And is your host a 64bit OS ?
Geospatial professional services
http://even.rouault.free.fr/services.html
