[gdal-dev] ogr2ogr ERROR 6: No translation
xavier lhomme
lhomme.xavier at gmail.com
Wed Apr 9 21:22:05 PDT 2014
Hi
You should specify the version of gdal you are using (and proj4 too).
Sometimes ago I used NGA Geotrans to perform GeoId conversion. But recent
version of proj4 are able to perform such conversion.
Le 10 avr. 2014 06:11, "Andre Joost" <andre+joost at nurfuerspam.de> a écrit :
Am 10.04.2014 04:31, schrieb Jason Mathis:
Hi All,
> On to the next problem:) I discovered today that I need to reproject
> the shape file before rasterizing it. I get the below error.
> Any ideas? Is it not possible?
What extent does your shapefile have?
Some projections are limited to the visible half of the globe.
HTH,
André Joost
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140410/60a6c58b/attachment.html>
