[gdal-dev] gdal_retile x64 : No input files selected.
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Apr 11 01:08:42 PDT 2014
Imran,
You need to specify the resampling algorithm if you use the -r option.
Choose from near, bilinear, cubic, cubicspline, lanczos.
'near' is used if you don't specify the -r option.
On Fri, Apr 11, 2014 at 12:45 PM, Imran Rajjad <rajjad at gmail.com> wrote:
> Hi list,
> I am using GDAL 10.1 x64 with Python 2.7.5 x64
> It seems python script is not able to find the input file
> W:\>gdal_retile.py -v -r -levels 4 -ps 2048 2048 -co "TILED=YES" -co
> "COMPRESS=JPEG" -targetDir w:\dem\dem_pyramid w:\dem\dem.tif
> 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
> Usage: gdal_retile.py
> [-v] [-co NAME=VALUE]* [-of out_format]
> [-ps pixelWidth pixelHeight]
> [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
> CInt16/CInt32/CFloat32/CFloat64}]
> [ -tileIndex tileIndexName [-tileIndexField fieldName]]
> [ -csv fileName [-csvDelim delimiter]]
> [-s_srs srs_def] [-pyramidOnly] -levels numberoflevels
> [-r {near/bilinear/cubic/cubicspline/lanczos}]
> [-useDirForEachRow]
> -targetDir TileDirectory input_files
> Can somebody tell me what is wrong with the command
> below is GDAL info of the geotiff file
> ---GDALINFO------
> W:\>gdalinfo dem\dem.tif
> Driver: GTiff/GeoTIFF
> Files: dem\dem.tif
> dem\dem.tif.aux.xml
> Size is 30001, 24001
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> Origin = (59.999583333323244,40.000416763514124)
> Pixel Size = (0.000833333333333,-0.000833333333333)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 59.9995833, 40.0004168) ( 59d59'58.50"E, 40d 0' 1.50"N)
> Lower Left ( 59.9995833, 19.9995834) ( 59d59'58.50"E, 19d59'58.50"N)
> Upper Right ( 85.0004167, 40.0004168) ( 85d 0' 1.50"E, 40d 0' 1.50"N)
> Lower Right ( 85.0004167, 19.9995834) ( 85d 0' 1.50"E, 19d59'58.50"N)
> Center ( 72.5000000, 30.0000001) ( 72d30' 0.00"E, 30d 0' 0.00"N)
> Band 1 Block=30001x1 Type=Int16, ColorInterp=Gray
> Description = Layer_1
> Min=-32768.000 Max=8469.000
> Minimum=-32768.000, Maximum=8469.000, Mean=-339.616, StdDev=7609.851
> NoData Value=0
> Metadata:
> LAYER_TYPE=athematic
> STATISTICS_HISTOBINVALUES=35892220|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0
> |0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0
> |0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|147192240|103498980|58861348|42041116
> |24849760|20456436|19853444|32923904|23568064|14391364|11251344|9393020|9059076|
> 8846812|7765888|6834360|6443632|6328036|5700032|5445180|5022004|4646148|4389944|
> 4296656|4444024|4944940|5610800|6424704|8513544|9714796|11723868|13505128|117576
> 68|8901568|6243536|4127656|2605304|1385800|671944|286624|116272|41912|27716|1352
> 0|10816|5408|4056|2028|676|0|0|0|676|
> STATISTICS_HISTOMAX=8469
> STATISTICS_HISTOMIN=-32768
> STATISTICS_HISTONUMBINS=256
> STATISTICS_MAXIMUM=8469
> STATISTICS_MEAN=-339.61644644564
> STATISTICS_MEDIAN=414.8984375
> STATISTICS_MINIMUM=-32768
> STATISTICS_MODE=-68.34765625
> STATISTICS_SKIPFACTORX=26
> STATISTICS_SKIPFACTORY=26
> STATISTICS_STDDEV=7609.8514119626
> regards,
> Imran
> I.R
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140411/cbf8bb2c/attachment.html>
