[gdal-dev] [ogr2ogr 1.10]EPSG 3943
Even Rouault
even.rouault at mines-paris.org
Fri Apr 11 10:23:14 PDT 2014
Le vendredi 11 avril 2014 18:46:35, Rémy GOURRAT a écrit :
> Hi,
> At the end of my command line ogr2ogr, i Try to attribute a SRS output with
> this syntax :
> -a_srs EPSG:3946
> But every time I have this message :
> ERROR 6: EPSG PCS/GCS code 3946 not found in EPSG support files. Is this a
> valid EPSG coordinate system? Failed to process SRS definition: EPSG:3946
> I check the pcs.csv and i get the line 3946 with the SRS def
> pcs.csv is in the same directory that ogr2ogr
Works for me. Check that the GDAL_DATA environment variable point to the path
where the CSV files are installed.
> I forget something ?
> Thanks for your help
> Rémy
Geospatial professional services
http://even.rouault.free.fr/services.html
