[gdal-dev] Questions about building 1.11.0beta1 on Windows
Carl Godkin
cgodkin at gmail.com
Tue Apr 15 08:11:02 PDT 2014
I tried out 1.11.0beta1 yesterday and today and everything I have tried
seems fine to me on Win64.
I have two small questions:
1. I really like the change in the Windows build procedure that introduces
the "nmake.local" include in which I can put many of my growing collection
of local edits. I say "many" instead of "all" because I don't see how to
effectively "comment out" a makefile variable using the nmake.local method.
For instance, I want to build without ODBC support. The nmake.opt file
contains the instruction
# Comment out the following to disable ODBC support.
ODBC_SUPPORTED = 1
Can anyone think of a way to undo the ODBC_SUPPORTED definition
(on by default) from nmake.local? The variable is later checked in three
places with "!IFDEF ODBC_SUPPORTED" so changing its value won't work, not
to mention that the nmake.local inclusion comes before ODBC_SUPPORTED
definition.
2. When building on Win64, I always notice lots of warnings (C4244 and
C4267) that arise because of implicit conversions from (say) size_t to int.
I was wondering why many open source projects (including GDAL) don't seem
to fix these - is it because the necessary casts make the code less
readable in someone's opinion? Or is it just because no one has gotten
around to it? If it's the latter, I would be willing to submit a ticket
with some patches. It seems a pity to build with /W4 but put up with so
many warnings.
Thanks,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140415/386146aa/attachment.html>
