[gdal-dev] gdal trunk version
Even Rouault
even.rouault at mines-paris.org
Sat Apr 19 02:16:21 PDT 2014
Le vendredi 18 avril 2014 23:37:47, Martin Landa a écrit :
> Hi,
> 2014-04-18 19:43 GMT+02:00 Even Rouault <even.rouault at mines-paris.org>:
> > I've switched to 1.12dev
> thanks, but how is possible that after running configure this file is
> changed
> Index: VERSION
> --- VERSION (revision 27216)
> +++ VERSION (working copy)
> @@ -1 +1 @@
> -1.12dev
> +1.11.0
Ah, good point. I actually forgot to increase GDAL_VERSION_MINOR in
gcore/gdal_version.h. And when you will run configure VERSION will be set to
"1.12.0" since configure uses the value of GDAL_VERSION_MAJOR, _MINOR, _MICRO
and not GDAL_RELEASE_NAME. Anyway the numbering system of trunk is pretty much
undefined between 2 official releases.
> Martin
Geospatial professional services
http://even.rouault.free.fr/services.html
