[gdal-dev] Motion: Promote 1.11.0RC1 for release
Kurt Schwehr
schwehr at gmail.com
Sun Apr 20 21:26:02 PDT 2014
What in the test output says that I don't have a working proj4?
Thanks for the clarifications on the other points. I can update the
checksums tomorrow.
-kurt
On Sun, Apr 20, 2014 at 10:38 AM, Even Rouault <even.rouault at mines-paris.org
> wrote:
> Le dimanche 20 avril 2014 18:20:58, Kurt Schwehr a écrit :
> > The proj.4 comment confuses me...
> > ./configure ... --with-static-proj4=/sw ...
> > checking how to link PROJ.4 library... link statically.
> > checking for pj_init in -lproj... yes
> > Statically link PROJ.4: yes
> > What am I missing?
> Hum, perhaps you only added --with-static-proj4 after a first build
> without it
> ? If so, touch ogr/ogrct.cpp before rebuilding.
> > The jpeg and png issues are (if I remember the discussions a few months
> > back) expected.
> Would be good if someone could update the checksums...
> > fink list -i proj libjpeg libpng16 | grep -v system
> > i libjpeg-bin 9a-1 Executables for libjpeg package
> > i libjpeg9 9a-1 JPEG image format handling library
> > i libjpeg9-shlibs 9a-1 Shared libraries for libjpeg package
> > i libpng16 1.6.10-1 PNG image format handling library
> > i libpng16-shlibs 1.6.10-1 Shared libraries for libpng16 package
> > i proj 4.8.0-3 Cartographic projections library
> > i proj-bin 4.8.0-3 Cartographic projections library
> > i proj-shlibs 4.8.0-3 Cartographic projections library
> > otool -L /sw/bin/gdalinfo | egrep 'jpeg|png'
> > /sw/lib/libjpeg.9.dylib (compatibility version 11.0.0, current version
> > 11.0.0)
> > /sw/lib/libpng16.16.dylib (compatibility version 27.0.0, current version
> > 27.0.0)
> I've reproduced the issue with the ICC profile with libpng 1.6.10 too.
> Filed as
> http://trac.osgeo.org/gdal/ticket/5441. Probably just an issue with the
> test
> data and libpng being pickier in recent versions.
> Geospatial professional services
> http://even.rouault.free.fr/services.html
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140420/6cd7a7ff/attachment.html>
