[gdal-dev] problem with gdal_translate jp2 file from the usgs (linux)
Even Rouault
even.rouault at mines-paris.org
Thu Apr 24 14:25:32 PDT 2014
Le jeudi 24 avril 2014 23:17:29, Kasper van Wijk a écrit :
> dear all,
> I am downloading jp2 data from the usgs national map. To plot this in
> cartopy, I need to transform to something else, such as geotiff. However,
> using gdal_translate I get a warning copied below, and the output is a
> grainy bw version of the image. I have checked my results under linux both
> fedora core 20 and ubuntu 12.04 versions with GDAL 1.7.3, released
> 2010/11/10
> gdal_translate m_3810623_ne_13_1_20110921_20111031.jp2 test.tiff -of GTiff
> warning: not enough tile data (2 bytes)
Apparently your GDAL build uses libjasper as the jpeg2000 library. Jasper
doesn't work very well unfortunately with some real world images.
You might want to compile GDAL against one of the other JPEG2000 libraries
that are supported : see http://gdal.org/formats_list.html
Geospatial professional services
http://even.rouault.free.fr/services.html
