[gdal-dev] problem with gdal_translate jp2 file from the usgs (linux)
Even Rouault even.rouault at mines-paris.org
Thu Apr 24 14:32:53 PDT 2014
Le jeudi 24 avril 2014 23:29:03, Kasper van Wijk a écrit :
> thank you, Even, for the fast reply. I am a beginner at GDAL and installed
> the gdal suite with "standard" apt-get and yum, respectively. Can you point
> me to a place where I can read how to compile GDAL against one of the other
> JPEG2000 libraries, as you say?
You will find various resources at http://trac.osgeo.org/gdal/wiki/BuildHints
Most interesting links for your use case :
* http://trac.osgeo.org/gdal/wiki/DownloadSource
* http://trac.osgeo.org/gdal/wiki/BuildingOnUnix
* http://trac.osgeo.org/gdal/wiki/ECW : if you want to compile against ECW SDK
* http://gdal.org/frmt_jp2openjpeg.html : if you want to compile against
OpenJPEG v2
> Thanks again,
> Kasper
> On 25 April 2014 09:25, Even Rouault <even.rouault at mines-paris.org> wrote:
> > Le jeudi 24 avril 2014 23:17:29, Kasper van Wijk a écrit :
> > > dear all,
> > > I am downloading jp2 data from the usgs national map. To plot this in
> > > cartopy, I need to transform to something else, such as geotiff.
> > > However, using gdal_translate I get a warning copied below, and the
> > > output is a grainy bw version of the image. I have checked my results
> > > under linux
> > both
> > > fedora core 20 and ubuntu 12.04 versions with GDAL 1.7.3, released
> > > 2010/11/10
> > > gdal_translate m_3810623_ne_13_1_20110921_20111031.jp2 test.tiff -of
> > GTiff
> > > warning: not enough tile data (2 bytes)
> > Apparently your GDAL build uses libjasper as the jpeg2000 library. Jasper
> > doesn't work very well unfortunately with some real world images.
> > You might want to compile GDAL against one of the other JPEG2000
> > libraries that are supported : see http://gdal.org/formats_list.html
> > Geospatial professional services
> > http://even.rouault.free.fr/services.html
