[gdal-dev] debug ogr2ogr on Windows
Ivan Lucena lucena_ivan at hotmail.com
Thu Apr 24 15:56:44 PDT 2014
I can't see why you can't debug in express version.
I used it for many years. That is why I created the makegdal_gen.bat.
But I don't use express edition now. I use Linux most of the time now.
> Date: Thu, 24 Apr 2014 22:44:44 +0100
> From: jluis at ualg.pt
> To: landa.martin at gmail.com
> CC: gdal-dev at lists.osgeo.org; david at stripfamily.net
> Subject: Re: [gdal-dev] debug ogr2ogr on Windows
> On 24-04-2014 22:20, Martin Landa wrote:
> > [back to ML]
> > 2014-04-24 23:18 GMT+02:00 David Strip<david at stripfamily.net>:
> >> do you have access to visual studio?
> > sure, as I noted, building using package.cmd script (nmake-based). I
> > have VS 2010 Express.
> Others can confirm this, but I'm afraid you wont be able to do an IDE debugging with an Express version. It's a petty because VS is really good for debugging.
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140424/890a3cc3/attachment.html>
