[gdal-dev] HDF4 python add band
Luca Delucchi lucadeluge at gmail.com
Sat Apr 26 15:22:03 PDT 2014
Hi everybody,
I'm working with HDF4Image and Python bindings, I would like to add
new band after create the layer.
When I try to use AddBand function it return:
ERROR 6: "FILENAME" Dataset does not support the AddBand() method.
It should be possible to make possible to use AddBand() also for this
format? Or there some other way to insert new band in HDF4Image
format?
Thanks
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
