[gdal-dev] accessing netCDF files with /vsicurl fails
Etienne Tourigny etourigny.dev at gmail.com
Sun Apr 27 18:59:49 PDT 2014
Even is right - it never worked with the netcdf driver.
But - it works if you use the vsipreload mechanism
e.g. http://lists.osgeo.org/pipermail/gdal-dev/2013-May/036359.html
On Sun, Apr 27, 2014 at 6:03 PM, Joaquim Luis <jluis at ualg.pt> wrote:
> On 27-04-2014 21:25, Even Rouault wrote:
>> Le dimanche 27 avril 2014 21:50:36, Joaquim Luis a écrit :
>>> Hi,
>>> This type of command used to work before, but it now errors  (fresh Win7
>>> 64 GDAL)
>> Joaquim,
>> I doubt it has ever worked with netCDF. The netCDF driver doesn't support
>> the
>> VSI Virtual file system API, since the I/O is done by the netCDF library
>> itself.
> hmmmmm, I would be willing to swear ... but better not
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140427/5746f523/attachment.html>
