[gdal-dev] accessing netCDF files with /vsicurl fails
Joaquim Luis
jluis at ualg.pt
Mon Apr 28 11:40:05 PDT 2014
Even,
I don't need it badly but it would be nice to have, so I will try to see
how far I'll be able to reach.
But do you mention the HDF4 lib? The issue happened with netCDF. Did you
mean HDF5?
> Le lundi 28 avril 2014 15:34:02, Joaquim Luis a écrit :
>> Thanks for the remainder Etienne, ... but the "Linux only" is a killing
>> feature for me.
> Well, if you really badly need it and are ready to do some development effort,
> you could still edit the HDF4 sources and basically add some #ifdef's in a
> global include file that they would all include
> #define fopen VSIFOpenL
> #define fclose VSIFCloseL
> #define fread VSIFReadL
> etc etc. you got the point.
> More points for you if you can do this in a cleaner way by defining a I/O API
> in HDF4 lib that would default to the standard C API (fopen, etc...), but
> could be overriden by GDAL to plug the VSI Large File API in it, and manage to
> make it accepted by HDF4 mainteners.
> Even
