[gdal-dev] postgis to esri shape slow
Even Rouault
even.rouault at mines-paris.org
Wed Apr 30 08:32:53 PDT 2014
Le mercredi 30 avril 2014 17:19:04, Mario Jurcevic a écrit :
> On 04/30/2014 05:11 PM, Even Rouault wrote:
> > Not that much a big difference... Perhaps you should try to isolate which
> > layer conversion if particuarly slower with ogr2ogr
> I get big difference:
> time ogr2ogr -sql 'select
> "soft_gis_serial","Origine","Qualita","Genere",st_curvetoline("Geometria")
> as Geometria from test_export."Copertura_del_suolo__SuperficieCS"'\
> > -f "ESRI Shapefile" out.shp PG:'host=localhost dbname=test_soft_gis
> user=test_soft_gis password=passwd'
> Warning 6: Normalized/laundered field name: 'soft_gis_serial' to
> 'soft_gis_s'
> real 0m2.359s
> user 0m0.040s
> sys 0m0.004s
> With debug on there there is many notice of ogr analyzing geom tables.
> Maybe that is, your dump miss has not the whole db.
I see ogrinfo reporting 167 layers.
The listing of spatial tables should be quite fast generally (in my case it
is). Perhaps you could try " tables=foo" (really 'foo' or another dummy
string) at the end of the OGR connexion string. This will skip that listing.
"soft_gis_serial","Origine","Qualita","Genere",st_curvetoline("Geometria") as
Geometria from test_export."Copertura_del_suolo__SuperficieCS"' out.shp
"pg:dbname=autotest host=127.0.0.1 port=5436 user=postgres tables=foo" -
overwrite --debug on
real 0m0.181s
user 0m0.110s
sys 0m0.020s
So this saves ~ 40 ms for me.
Geospatial professional services
http://even.rouault.free.fr/services.html
