[gdal-dev] OGR: memory leak in OCI driver
SIMON Nicolas
nicolas.simon at spw.wallonie.be
Fri Aug 1 07:49:35 PDT 2014
Hi list,
We tested the suggestion of Ivan and it's better.
Fortunately, my problem to create ticket was solved
The ticket is http://trac.osgeo.org/gdal/ticket/5599 with a patch file.
Best regards
Nicolas
De : Ivan Lucena [mailto:lucena_ivan at hotmail.com]
Envoyé : mardi 6 mai 2014 17:48
À : SIMON Nicolas; gdal-dev at lists.osgeo.org
Cc : SANDRI Christophe; NGUYEN Thi Xuan Truc
Objet : RE: [gdal-dev] OGR: memory leak in OCI driver
Hi Nicolas,
I received that report a month ago:
"we have found the OGROCISession is never released, causing a large memory leak whenever a connection is closed.
As workaround, we added in OGROCISession::~OGROCISession()
if( hEnv )
OCIHandleFree((dvoid *) hEnv, (ub4) OCI_HTYPE_ENV);"
But they also mention some other memory leaks without an specific location on the code.
Can you try to see if that fix the problem?
Thanks,
Ivan
From: nicolas.simon at spw.wallonie.be<mailto:nicolas.simon at spw.wallonie.be>
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Date: Tue, 6 May 2014 15:32:09 +0000
CC: christophe.sandri at spw.wallonie.be<mailto:christophe.sandri at spw.wallonie.be>; xuan.nguyen at spw.wallonie.be<mailto:xuan.nguyen at spw.wallonie.be>
Subject: [gdal-dev] OGR: memory leak in OCI driver
Dear developers,
I suspect that there is a memory leak in OCI driver for OGR
My simplified test case is :
// point A
OGRRegisterAll();
// point B
pDS = OGRSFDriverRegistrar::Open("OCI:USER/PWD at INSTANCE:TABLE", true);
if(pDS)
OGRDataSource::DestroyDataSource(pDS);
pDS = NULL;
else
fprintf(fOut,"Erreur Open\n");
// point C
OGRCleanupAll();
// point D
It appears that I lose memory between points B and C, and between point A and D
B = A + 4 MB
C = A + 20 MB ( 16 MB lost)
D = A +19 MB ( 3 more MB lost)
Test was done with GDAL 1.9 under windows (with Oracle 11g)
Can some one have an idea to find and fix this ?
Thank you
By the way, I received « TICKET_CREATE privileges are required to perform this operation » when I tried to make a ticket (UID nicsim)
Nicolas
_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140801/64b51a99/attachment-0001.html>
