[gdal-dev] Usage of styles in C API
Nik Sands
nixanz at nixanz.com
Sun Aug 3 03:41:56 PDT 2014
Sorry, my mistake... I had my logging in the wrong place. styleChars is actually of the form (including the leading space):
' PEN(c:#A08080,w:2pt); LABEL(c:#000000,s:18pt,t:{title})'
On 3 Aug 2014, at 8:35 pm, Nik Sands <nixanz at nixanz.com> wrote:
> On one of the iterations through this code, styleChars is:
> 'vegetation_low: BRUSH(fc:#A0F0A0); LABEL(c:#004000,s:18pt,t:{title})'
> So perhaps the inclusion of the style name is the problem?
> This was read into a style table from a text file using 'OGR_STBL_LoadStyleTable()'. I had assumed that a similar format to .ofs was suitable. If this is not the case, how should I read a style table from a text file in such a way that I can distinguish the various styles by name?
> In guess my more general question is: What is the correct way to read styles from an arbitrary text file into a style table, and then use a style manager to get the various parts/tools?
> On 3 Aug 2014, at 8:26 pm, Even Rouault <even.rouault at mines-paris.org> wrote:
>> Le dimanche 03 août 2014 12:11:42, Nik Sands a écrit :
>>> I'm just starting out using the styles features of OGR (using the C API)
>>> but at struggling with a few elements of it.
>>> My code (copied below) fails to get any OGRStyleToolH. Ie, the "if ( tool
>>> )" block never gets run, because 'tool' is always NULL at the point
>>> indicated by the comment. But the execution does reach that point in the
>>> code which indicates that the OGRStyleMrgH does in fact include at least
>>> one part (tool).
>>> I'd be grateful if somebody could point out what I'm doing wrong.
>> Nothing strikes me as wrong. A potential explanation is that styleChars
>> doesn't contain a valid OGR Feature Style string.
>> GetPartCount() counts the number of ";" separating style parts, but it doens't
>> check that each style part actually begins by a recognized tool name (PEN,
>> BRUSH, SYMBOL, LABEL). OGR_SM_GetPart() does this check however and if it
>> cannot recognize it it returns a NULL tool.
>>> Thanks,
>>> Nik.
>>> const char *styleChars = OGR_STBL_GetNextStyle(table) ) )
>>> NSString *styleName = [NSString
>>> stringWithUTF8String:OGR_STBL_GetLastStyleName(table)]; OGRStyleMgrH
>>> styleMgr = OGR_SM_Create(NULL);
>>> OGR_SM_InitStyleString(styleMgr, styleChars);
>>> for ( int i = 0; i < OGR_SM_GetPartCount(styleMgr, NULL); i++ )
>>> OGRStyleToolH tool = OGR_SM_GetPart(styleMgr, i, NULL);
>>> if ( tool ) // 'tool' always NULL here
>>> switch ( OGR_ST_GetType(tool) )
>>> case OGRSTCPen:
>>> self.pen = tool;
>>> break;
>>> case OGRSTCBrush:
>>> self.brush = tool;
>>> break;
>>> case OGRSTCSymbol:
>>> self.symbol = tool;
>>> break;
>>> case OGRSTCLabel:
>>> self.label = tool;
>>> break;
>>> default:
>>> NSLog(@"Unknown style tool type!");
>>> break;
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Geospatial professional services
>> http://even.rouault.free.fr/services.html
