[gdal-dev] GSoC 2014 Weekly Report 11 : GDAL PostGIS Raster driver
Varun Saraf varunsaraf14 at gmail.com
Mon Aug 4 13:38:20 PDT 2014
Hello,
Thank you for this information. I will explicitly call Create() using a
script. Is the IWriteBlock method to be tested in a similar manner? Note
that pData buffer is passed to this method as an argument, which I will
have to generate and pass to it. Any suggestions how I should generate this
pData buffer?
Regards,
Varun Saraf
On Tue, Aug 5, 2014 at 1:44 AM, Even Rouault <even.rouault at mines-paris.org>
wrote:
> Le lundi 04 août 2014 21:38:36, Varun Saraf a écrit :
> > Hello,
> > Yes, the code on the github repository is the latest state. I was trying
> > the following input queries :
> > (1) Assuming that my Create() will be called.
> > gdal_translate --debug ON -of PostGISRaster ~/GSoC/ap_clip5x5.tif
> >  PG:"host=localhost port=5432 user=postgres password=postgres
> > dbname=test123 table=newtable"
> > (2) When that did not work, I tried the following (suggested by my
> mentor,
> > Jorge Arevalo) which didn't work either.
> > gdal_translate --debug ON -of PostGISRaster -outsize 50% 50%
> > ~/GSoC/ap_clip5x5.tif  PG:"host=localhost port=5432 user=postgres
> > password=postgres dbname=test123 table=newtable"
> gdal_translate will never call Create(), but only CreateCopy().
> You might want to call Create() directly with a Python script for example,
> or
> a sample C/C++ code. gdalwarp will call Create() too, but gdalwarp can
> potentially rewrite existing tiles, which can complicate your initial
> coding.
> > QuiteDelete() method is called in both cases and the following error
> > messages are shown
> > ERROR 1: Couldn't drop the table public.newtable: ERROR:  table
> "newtable"
> > does not exist
> > ERROR 6: PostGISRasterDataset::CreateCopy() only works on source datasets
> > that are PostGISRaster
> Yes, as the message implies, the current CreateCopy() implementation only
> works when the source dataset is a postgisraster dataset itself.
> As far as the error message "Couldn't drop ...",
> PostGISRasterDataset::Delete() should probably be more silent in case the
> dataset doesn't exist.
> Note that once you have a full feature Create() implementation (with
> working
> IWriteBlock() of course), CreateCopy() is no longer strictly needed, since
> there is generic implementation in GDAL core that will emulate CreateCopy()
> with Create() + IWriteBlock()
> > I even tried calling the Create() method directly from CreateCopy(),
> since
> > that is being called, but again the same error message is being printed.
> > Regards,
> > Varun Saraf
> > On Mon, Aug 4, 2014 at 11:33 PM, Even Rouault
> > wrote:
> > > Le lundi 04 août 2014 14:39:52, Varun Saraf a écrit :
> > > >  Hi,
> > > > Below is my eleventh weekly report.
> > > > *What did I do this week?*
> > > >    - There are some issues with the calling of different methods. My
> > > method
> > > >    PostGISRasterDataset::Create() is not being called. Tried to
> resolve
> > > > that.
> > > Varun,
> > > If the code at
> https://github.com/varunsaraf/postgis_raster/blob/master/postgisrasterdat
> > > aset.cpp is the latest state, I don't see any reason why your Create()
> > > method wouldn't
> > > be called. Do you try to trigger it directly by calling Create()
> > > explicetely
> > > or through other more high level operations ?
> > > Even
> > > > - Fixed some small bugs and removed unnecessary variables that were
> > > > being used.
> > > > *What do I plan on doing next week?*
> > > >    - Continue with testing and bug fixing.
> > > > *Am I blocked on anything?*
> > > >    - No.
> > > > Link to weekly report :
> > > > https://github.com/varunsaraf/postgis_raster/wiki/Report-11
> > > > Link to code repository :
> > > > More details at :
> http://trac.osgeo.org/gdal/wiki/PostGIS_raster_driver
> > > > Regards,
> > > > Varun Saraf
> > > > Lab for Spatial Informatics
> > > > IIIT Hyderabad, India
> > > Geospatial professional services
> > > http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140805/4534b86d/attachment.html>
