[gdal-dev] NITF read slow in python
John_Lunzer lunzer at gmail.com
Wed Aug 6 11:38:55 PDT 2014
The documentation states that Python automatically calls GDALAllRegister()
when the GDAL module is imported. Is there any way to disable this or to
tell GDAL to use a specific driver when loading JPEG2000 compressed images?
Even Rouault-2 wrote
> Le mercredi 06 août 2014 20:16:57, John_Lunzer a écrit :
>> They are listed as C8, which means JPEG2000 compression.
> That must be it. JPEG2000 decompression takes some time, and that can be
> more
> or less slow depending on the underlying driver used. Do you have JP2KAK,
> JP2ECW, JP2OPENJPEG, JP2MrSID or JPEG2000 drivers enabled ? (if you have
> several, they are used in the mentionned order)
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/NITF-read-slow-in-python-tp5155297p515
>> 5304.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
> gdal-dev at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev at .osgeo
View this message in context: http://osgeo-org.1560.x6.nabble.com/NITF-read-slow-in-python-tp5155297p5155309.html
