[gdal-dev] GDAL, ESRI Shapefiles and nested polygons
Graeme Wilkie
graeme.wilkie at btinternet.com
Fri Aug 8 06:19:38 PDT 2014
You were correct, it is returning multipolygon (9sorry, I should have included that information).
I've made the change you suggested so the code looks like
Int index = 0;
OGRGeometryH hGeometry = OGR_F_GetGeometryRef(hFeature);
int shape_type = wkbFlatten(ORG_G_GetGeometry(hGeometry);
int num_geom = OGR_G_GetGeometryCount(hGeometry) - 1; // Returns a valid result
int innerIndex = 0;
do
OGRGeometryH hRing = OGR_G_GetGeometryRef(hGeometry, index);
OGRGeometryH tmpGeo = OGR_G_GetGeometryRef(hRing, innerIndex);
Int num_vertices = OGR_G_GetPointCount(tmpGeo);
//. Do something with the data
Index++;
// Destroy the hfeature here
If innerIndex is 0 then I can read the data for that polygon. If innerIndex in 1 then tmpGeo is NULL even though there are 2 inner polygons in the test data.
Have I do something stupid ?
The test data is a simple square with 2 squares inside it created using shapefile.py
If anybody has a small piece of example could it would be a great help.
Regards
Graeme
To: gdal-dev at lists.osgeo.org
Cc: Graeme Wilkie <graeme.wilkie at btinternet.com>
Sent: Thursday, August 7, 2014 9:26 PM
Subject: Re: [gdal-dev] GDAL, ESRI Shapefiles and nested polygons
Le jeudi 07 août 2014 22:20:34, Graeme Wilkie a écrit :
> Hi,
> I'm trying to use GDAL to read ESRI shapefiles. I've got it working for
> points, lines, polygons, polylines and multipoint but I'm having problems
> with polygons that contain polygons in the same feature.
> The following is a cut down code sample of the code I'm using. The problem
> I have is that I can read the number of polygons in the feature (i.e. 3
> polygons, nested) using OGR_G_GetGemoetryCount. When I use
> OGR_R_GetGeometryRef to get the handle/pointer for each of the polygons in
> turn I get what appears to be a valid handle but when I use it to get the
> number of points/vertices in the polygon it always returns 0.
Graeme,
You didn't display the WKT that corresponds to the geometry, so I will just
make the guess that the geometries returned is a multipolygon and not a
polygon.
So you might need one more level of OGR_G_GetGeometryCount and
OGR_G_GetGeometryRef to go to the ring level.
Best regards,
Even
http://www.spatialys.com/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140808/f71344eb/attachment.html>
