[gdal-dev] Losing access to dataset variables. Am I doing something really dumb?
Even Rouault
even.rouault at spatialys.com
Tue Aug 12 01:02:57 PDT 2014
Hi Jorge,
I don't see anything obviously wrong. Looking at the places where the variables
might be nullified and running Valgrind would be my best advice.
Just wanted to mention that in the likely simplified below snippet, you would
leak memory.
Even
> Hello,
> I have a stupid mistake in my code. This is the problem (very simplified):
> postgisrasterdataset.cpp
> PostGISRasterDataset::IRasterIO(....)
> // Two attributes of my class, that inherits from GDALDataset
> pszAttribute = CPLStrdup("foo");
> pszAttribute2 = CPLStrdup("bar");
> // Just delegates in default implementation
> return GDALDataset::IRasterIO(...);
> postgisrasterrasterband.cpp
> PostGISRasterRasterBand::IRasterIO(....)
> // Get pointer to dataset this rasterband belongs to
> PostGISRasterDataset * poRDS = (PostGISRasterDataset *)poDS;
> // Do some stuff with poRDS->pszAttribute and poRDS->pszAttribute2
> // They're private vars, but PostGISRasterRasterBand and
> // PostGISRasterDataset are friends. No problem here.
> // Delegates in default implementation. So, this will result, at the
> end, in calls
> // to my implementation of IReadBlock / IWriteBlock
> return GDALRasterBand::IRasterIO(...);
> PostGISRasterRasterBand::IWriteBlock(...)
> // Try to work with poRDS->pszAttribute and poRDS->pszAttribute2, but
> // fails because they are NULL. Why??
> Weirdest thing is the rest of cuestom attributes of my PostGISRasterDataset
> class are accessible. And, of course, the poRDS pointer is always the same
> (same mem address). Only problem is with those char * attributes. Looks
> like they're freed at some point (or I'm doing something really wrong from
> the point of view of C++, and I deserve a severe punishment for that).
> Any clues?
> Best regards,
> Jorge Arevalo
> http://about.me/jorgeas80
http://www.spatialys.com
