[gdal-dev] Losing access to dataset variables. Am I doing something really dumb?
Even Rouault
even.rouault at spatialys.com
Tue Aug 12 01:29:27 PDT 2014
Selon Jorge Arevalo <jorgearevalo at libregis.org>:
> Hi Even,
> Thanks for your hints. About the memory leaking, apart from the obvious
> fact that CPLStrdup vars need to be freed, are you seeing something more?
No, that was indeed what I meant. Not much more that could leak in the snippet
> On Tue, Aug 12, 2014 at 9:48 AM, Even Rouault <even.rouault at mines-paris.org>
> wrote:
> > Hi Jorge,
> > I don't see anything obviously wrong. Looking at the places where the
> > variables
> > might be nullified and running Valgrind would be my best advice.
> > Just wanted to mention that in the likely simplified below snippet, you
> > would
> > leak memory.
> > Even
> > > Hello,
> > > I have a stupid mistake in my code. This is the problem (very
> > simplified):
> > > postgisrasterdataset.cpp
> > > PostGISRasterDataset::IRasterIO(....)
> > > // Two attributes of my class, that inherits from GDALDataset
> > > pszAttribute = CPLStrdup("foo");
> > > pszAttribute2 = CPLStrdup("bar");
> > > // Just delegates in default implementation
> > > return GDALDataset::IRasterIO(...);
> > > postgisrasterrasterband.cpp
> > > PostGISRasterRasterBand::IRasterIO(....)
> > > // Get pointer to dataset this rasterband belongs to
> > > PostGISRasterDataset * poRDS = (PostGISRasterDataset *)poDS;
> > > // Do some stuff with poRDS->pszAttribute and poRDS->pszAttribute2
> > > // They're private vars, but PostGISRasterRasterBand and
> > > // PostGISRasterDataset are friends. No problem here.
> > > // Delegates in default implementation. So, this will result, at the
> > > end, in calls
> > > // to my implementation of IReadBlock / IWriteBlock
> > > return GDALRasterBand::IRasterIO(...);
> > > PostGISRasterRasterBand::IWriteBlock(...)
> > > // Try to work with poRDS->pszAttribute and poRDS->pszAttribute2, but
> > > // fails because they are NULL. Why??
> > > Weirdest thing is the rest of cuestom attributes of my
> > > class are accessible. And, of course, the poRDS pointer is always the
> > same
> > > (same mem address). Only problem is with those char * attributes. Looks
> > > like they're freed at some point (or I'm doing something really wrong
> > from
> > > the point of view of C++, and I deserve a severe punishment for that).
> > > Any clues?
> > > Best regards,
> > > Jorge Arevalo
> > > http://about.me/jorgeas80
http://www.spatialys.com
