[gdal-dev] GDAL - GDB issue
Scott Rowles
scott_rowles at hotmail.com
Fri Aug 15 18:53:09 PDT 2014
Even,
I found a new error when parsing a very large file. Seems to be something in one of the source files: line 1064
Can you give me an idea what this might be?
scott
> Date: Fri, 15 Aug 2014 22:52:32 +0200
> From: even.rouault at spatialys.com
> To: scott_rowles at hotmail.com
> CC: even.rouault at spatialys.com; gdal-dev at lists.osgeo.org
> Subject: RE: [gdal-dev] GDAL - GDB issue
> Selon Scott Rowles <scott_rowles at hotmail.com>:
> > OK. It threw some errors about a missing .csv file which I didn't have
> > installed in the solution. Working on adding that now. Why doesn't ogr.Open
> > return a more clear error?
> Please keep the list CC'ed. And when you mention errors that are thrown, you
> should copy them verbatim to avoid crystal glass guessing ;-)
> Well, I suppose it must have been about the gcs.csv/pcs.csv files that contain
> the EPSG projection database. Try to locate where they are installed in your
> distribution and define the GDAL_DATA environment variable to point to the
> directory where they are located.
> > > Date: Thu, 14 Aug 2014 19:45:09 +0200
> > > > Even,
> > > > No. Where do I find/download the ogrInfo utility. I will try that!
> > > It should be included in every binary distribution of gdal (e.g.
> > > http://gisinternals.com/sdk/). Or if you compile it from source. It is one
> > of
> > > the many utilities coming with the GDAL library.
> > > > scott
> > > > > Date: Thu, 14 Aug 2014 19:25:40 +0200
> > > > > CC: gdal-dev at lists.osgeo.org
> > > > > Subject: Re: [gdal-dev] GDAL - GDB issue
> > > > > > Hi,
> > > > > > I have an implementation with C# using GDAL 1.11 binaries. According
> > to
> > > > the
> > > > > > documentation it should process GDB files either as a .zip file, as a
> > > > .gdb
> > > > > > folder or as a .gdbtalbe individually.
> > > > > > I have tried all 3 of them and each one gives me an ogc.Open, cannot
> > open
> > > > > > this file type error.
> > > > > > Is there a switch I need to set or anything I need to do in the GDAL
> > > > > > configuration to enable GDB conversion?
> > > > > Well, it should work. Did you try with the ogrinfo utility to see if
> > the
> > > > dataset
> > > > > is recognized ?
> > > > > Even
> > > > > Spatialys - Geospatial professional services
> > > > > http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140815/4fbc9a61/attachment.html>
