[gdal-dev] Build GDAL from scratch on CentOS 6.5 (Jake Brinkmann)
Jake Brinkmann jakebrinkmann at gmail.com
Mon Aug 18 06:54:50 PDT 2014
Hey Daniel,
Much appreciated! I think building my own on a VM might be the next thing I
try.
I attempted to use jevans version, with a fresh install of Anaconda, but to
no avail.
The code here: https://gist.github.com/jake-brinkmann/fb4bd3f4625b209978d0
still didn't work.
I'll look through the examples to attempt again after building my own
package.
Thank you!
Jake
On Sat, Aug 16, 2014 at 4:34 AM, Daniel Clewley <daniel.clewley at gmail.com>
wrote:
> Hi Jake,
> As you mentioned Anaconda Python, one options is to install a different
> GDAL build from binstar someone has built with HDF4 support or build
> yourself using the conda build system on a virtual machine you have root
> access to and then install these binaries through conda.
> A quick search of binstar.org showed the following user with GDAL built
> against HDF4:
> https://binstar.org/jevans
> You should be able to install this version of GDAL through conda using:
> conda install -c https://conda.binstar.org/jevans gdal
> Note: I haven't tested this.
> Building your own packages is a bit more involved - basically you create a
> recipe and then build it using:
> conda build recipe-folder
> There is a github repository with lots of examples here:
> https://github.com/conda/conda-recipes/
> We've built GDAL and other software through conda for Linux and OS X under
> virtual machines and installed on different machines (without root access)
> and it's worked pretty well.
> Hope this helps and the discussion of conda isn't too off topic.
> Thanks,
> Dan
> On 15 Aug 2014 23:11, Even Rouault <even.rouault at spatialys.com> wrote:
> > Jake,
> > well if you don't have the basic build dependencies, this might get
> > complicated... Nothing impossible, but might take time indeed.
> > Well one possibility is to access a CentOS where you have a root access
> (e.g. a
> > VM that you install), build on it, and then copy the resulting binaries.
> > Even
> >> Hey Even,
> >> Thank you for outlining this. The trouble I have is that, without root
> >> access, `make install` is a never-ending list of missing libraries, or
> >> compilation errors...
> >> Do you know of a way to resolve the missing libraries without root
> access
> >> (and without wasting the next 48hours untaring, compiling, and
> installing)?
> >> Just as an example, I cant even compile the HDF4 source with
> `./configure
> >> --prefix=/have/write/access` because of something with Fortran and
> g77... I
> >> disable fortran as `./configure --prefix=/have/write/access
> >> --enable-fortran=NO` but then it fails due to missing yacc utility....
> This
> >> continues until I get so lost as to what library I'm installing for what
> >> package, that it just seems there must be an easier way...
> >> If you have any thoughts, please, let me know.
> >> Thank you for reaching out.
> >> Jake
> >> On Fri, Aug 15, 2014 at 4:45 PM, Even Rouault <
> >> wrote:
> >>> Selon Jake Brinkmann <jakebrinkmann at gmail.com>:
> >>>> Hello all geospatial-web-wizards,
> >>>> I am struggling pretty hard building the GDAL libraries and all the
> >>>> countless dependencies from source in CentOS6.5. I do not have root
> >>> access
> >>>> on my machine, but I need the GDAL (as well as HDF, GeoTiff, GEOS,
> etc.)
> >>>> libraries for performing image processing using the Terra/Aqua MODIS
> >>>> satellite remote sensing data.
> >>>> Does anyone out there have experience building GDAL along with HDF and
> >>>> Python bindings, but without, and I emphasize here: *without* root
> >>> access?
> >>>> Alternatively, if possible, I would be willing to install a binary,
> but
> >>>> remember: I do not have root access (so I'm not sure this would
> work...)
> >>>> and lack experience with *.rpm files
> >>>> Let me know, please, if anyone has any ideas at all.
> >>>> I am really wishing the Anaconda Python distribution would come with
> GDAL
> >>>> supporting HDF4, but it currently does not...
> >>>> Thanks for reading, and any help you can provide,
> >>> Jake,
> >>> It is always possible to build without root access.
> >>> The scheme is :
> >>> 1) Download HDF4 sources, untar, cd to the source directory
> >>> 2) ./configure --prefix=/somewhere/where/you/have/write/access
> >>> 3) make install
> >>> 4) Download GDAL sources, untar, cd to the source directory
> >>> 5) ./configure --prefix=/somewhere/where/you/have/write/access
> >>> --with-hdf4=/somewhere/where/you/have/write/access
> >>> 6) make install
> >>> 7) cd swig/python
> >>> 8) python setup.py build
> >>> 9) export PYTHONPATH=$PWD/build/lib.linuxXXXXXXXX (to be adapted
> depending
> >>> on
> >>> your architecture and Python version)
> >>> 10) export PATH=/somewhere/where/you/have/write/access/bin:$PATH
> >>> 11) export LD_LIBRARY_PATH=/somewhere/where/you/have/write/access/lib
> >>> You should be done.
> >>> Even
> >>> Spatialys - Geospatial professional services
> >>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140818/9608fc5b/attachment-0001.html>
