[gdal-dev] Planning for 1.11.1 release ?
Even Rouault
even.rouault at spatialys.com
Tue Aug 19 06:53:39 PDT 2014
The 1.11 branch has accumulated 57 fixes [1] since the 1.11.0 release (perhaps a
bit more if some of them went to the 1.10 branch as well), so it might be good
to think producing a maintenance release with them.
What do you think of end of September to produce an RC (let's say September
24th) ?
If there are outstanding regressions that should be fixed for 1.11.1, raise
tickets and cook up your patches !
There are 7 tickets currently opened against 1.11.1 milestone ([2]). GDAL
committers, please have a look at them and update milestone if needed.
Anyone volunteering to do the release process ? If nobody else wants, I will.
Best regards,
Even
[1]
http://trac.osgeo.org/gdal/query?status=closed&group=resolution&order=priority&milestone=1.11.1&resolution=fixed
[2]
http://trac.osgeo.org/gdal/query?status=assigned&status=new&status=reopened&group=resolution&order=priority&col=id&col=summary&col=owner&col=type&col=priority&col=component&col=version&milestone=1.11.1
http://www.spatialys.com
