[gdal-dev] RFC 15: Band Masks vs #5621
Ivan Lucena lucena_ivan at hotmail.com
Tue Aug 19 22:00:40 PDT 2014
That question is probably for Even, Frank or some the developer of drivers that support mask band.
I am working on ticket #5621 and trying to adapt it to the RFC 15 but I am not quite sure that I am getting it right.
In GeoRaster, I can have a bitmap mask band that can be applied to all bands, similar to the concept of GMF_PER_DATASET, I guess. I can also have one bitmap mask band per raster band, but that does not correspond to the others mask flags (GMF_ALL_VALID, GMF_ALHA, GMF_NO_DATA). The data type of my bitmap mask is 1 bit, and there is no implicit connection with Alpha Channel or No Data in a binary bitmap mask, of course.
So if I have a dataset with just one bitmap mask shared between all the bands, I think I can return the flag GMF_PER_DATASET and promote the values to GDT_BYTE. But if I have bitmap masks for each raster bands, then I don't know what flag to return. I might just lie and say "GMF_PER_DATASET" and when the mask is requested I will take care of returning the correct one.
Would that works for others drivers participating on gdal_translate/CreateCopy()?
Of course, if the output driver support just one mask per dataset, there is nothing much we can do.
By the way, are there any driver that support overviews of mask band?
Regards,
Ivan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140820/45d4bb81/attachment.html>
