[gdal-dev] Warping Issues
M Lewis
Martin.Lewis at euro.ngc.com
Wed Aug 20 03:05:24 PDT 2014
Thanks for the quick reply Evan.
I have done what you asked and it gets a bit strange.
I ran gdalinfo from the QGIS bin directory and then on the alternate machine
ran gdalinfo from the 'pure gdal' bin directory on the same sid file.
There are some differences in the output particularly around the definition
if the PROJCS and in particular the definition of the 'false_easting'.
The decoded Corner Coordinates are also different probably due to this
'false_easting' discrepency.
Still at a loss to understand the difference between the QGIS GDAL version
and the built gdal on the other machine.
Is it a bad build?
Wrong Proj4 datasets?
Or just an issue with GDAL/MrSID integration that QGIS seems to have
overcome? (If they have overcome it then it would be nice to have an
indication of how)
Output from QGIS gdal info
Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)
Files: E:\Stuff\Maps\georgiaville_se.sid
Size is 5189, 6945
Coordinate System is:
*PROJCS["NAD83 / Rhode Island",*
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",41.08333333333334],
PARAMETER["central_meridian",-71.5],
PARAMETER["scale_factor",0.99999375],
* PARAMETER["false_easting",328083.3333333333],*
PARAMETER["false_northing",0],
* UNIT["US survey foot",0.3048006096012192,
AUTHORITY["EPSG","9003"]]]*
Origin = (311060.109583333310000,311248.359216666660000)
Pixel Size = (3.280833333333334,-3.280833333333334)
Metadata:
GEOTIFF_CHAR__GTModelTypeGeoKey=ModelTypeProjected
GEOTIFF_CHAR__GTRasterTypeGeoKey=RasterPixelIsArea
GEOTIFF_CHAR__ProjectedCSTypeGeoKey=PCS_NAD83_Rhode_Island
GEOTIFF_CHAR__ProjLinearUnitsGeoKey=Linear_Foot_US_Survey
GEOTIFF_NUM__1024__GTModelTypeGeoKey=1
GEOTIFF_NUM__1025__GTRasterTypeGeoKey=1
GEOTIFF_NUM__1026__GTCitationGeoKey=IMAGINE GeoTIFF Support
Copyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: egtf.c $ $Revision: 1.10.1.6 $ $Date: 2003/10/17 16:36:51EDT $
Projection Name = State Plane
Units = feet
GeoTIFF Units = feet
GEOTIFF_NUM__3072__ProjectedCSTypeGeoKey=32130
GEOTIFF_NUM__3073__PCSCitationGeoKey=IMAGINE GeoTIFF Support
State Plane Zone -3800
NAD = 83
GEOTIFF_NUM__3076__ProjLinearUnitsGeoKey=9003
IMAGE__COMPRESSION_BLOCK_SIZE=512
IMAGE__COMPRESSION_GAMMA=2.000000
IMAGE__COMPRESSION_NLEV=7
IMAGE__COMPRESSION_VERSION=2,0,0
IMAGE__COMPRESSION_WEIGHT=2.000000
IMAGE__CREATION_DATE=Mon Feb 07 13:53:36 2005
IMAGE__INPUT_FILE_SIZE=108169367.000000
IMAGE__INPUT_FORMAT=GeoTIFF
IMAGE__INPUT_NAME=E:\Aerials\USDA\TIFS\4107104_se.tif
IMAGE__TARGET_COMPRESSION_RATIO=25.000000
VERSION=MG2
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
*Upper Left ( 311060.110, 311248.359) ( 71d33'45.24"W, 41d56'15.01"N)
Lower Left ( 311060.110, 288462.972) ( 71d33'45.02"W, 41d52'29.91"N)
Upper Right ( 328084.354, 311248.359) ( 71d29'59.99"W, 41d56'15.07"N)
Lower Right ( 328084.354, 288462.972) ( 71d29'59.99"W, 41d52'29.97"N)
Center ( 319572.232, 299855.665) ( 71d31'52.56"W, 41d54'22.51"N)*
Band 1 Block=1024x128 Type=Byte, ColorInterp=Red
Minimum=23.000, Maximum=253.000, Mean=76.340, StdDev=27.247
Overviews: 2595x3473, 1298x1737, 649x869, 325x435, 163x218, 82x109, 41x55
Band 2 Block=1024x128 Type=Byte, ColorInterp=Green
Minimum=36.000, Maximum=254.000, Mean=92.388, StdDev=23.622
Band 3 Block=1024x128 Type=Byte, ColorInterp=Blue
Minimum=46.000, Maximum=254.000, Mean=82.477, StdDev=21.573
Output from 'pure gdal' gdalinfo
Files: C:\Stuff\MrSid\Georgiaville_SE\georgiaville_se.sid
Size is 5189, 6945
*PROJCS["State Plane",*
GEOGCS["NAD83",
* PARAMETER["false_easting",1076386.736111111],*
* UNIT["feet",0.3048006096012192]]*
Metadata:
Units = feet
NAD = 83
VERSION=MG2
INTERLEAVE=PIXEL
Corner Coordinates:
*Upper Left ( 311060.110, 311248.359) ( 74d18'40.33"W, 41d54'11.14"N)
Lower Left ( 311060.110, 288462.972) ( 74d18'30.47"W, 41d50'26.31"N)
Upper Right ( 328084.354, 311248.359) ( 74d14'55.46"W, 41d54'16.59"N)
Lower Right ( 328084.354, 288462.972) ( 74d14'45.82"W, 41d50'31.75"N)
Center ( 319572.232, 299855.665) ( 74d16'43.02"W, 41d52'21.46"N)*
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Warping-Issues-tp5157231p5157277.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
