[gdal-dev] Warping Issues
M Lewis Martin.Lewis at euro.ngc.com
Wed Aug 20 05:06:54 PDT 2014
Thanks Evan but I am not quite sure I understand.
Are you saying that QGIS uses gdal built with a different MrSID SDK?
I have built GDAL using this version, MrSID_DSDK-9.0.0.3864-win32-vc11 from
LizardTech, which I think is the latest.
If it is then I am sure that QGIS will be using the same, in which case I
still can't see why they are producing different results?
Thanks
Martin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Warping-Issues-tp5157231p5157317.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
