[gdal-dev] Warping and creating tiles using C++
Nicu Tofan
nicu.tofan at gmail.com
Wed Aug 20 17:26:19 PDT 2014
Hello,
I'm working on an application with requirements described below. Please
have a look at what I came up with so far and tell me if I'm on an awfully
wrong path.
Requirements
Application takes as input a number of image files +/- geo-referenced
Input may have different resolutions, SRS, bands
The user can alter projection and geo-reference parameters
Output consists of tiles resulting from all those images;
The arrangement of the tiles can be customized (the way tiles are arranged
and named)
gdalbuildvrt, gdalwarp and gdal2tiles.py indicate that these requirements
can be satisfied by gdal.
Implementation
- for each input dataset create a virtual dataset using
GDALAutoCreateWarpedVRT(); this takes into consideration the changes
made by the user and target SRS
- follow the steps in gdalbuildvrt (CreateVRTNonSeparate) to generate a
single virtual file; this involves GDALProxyPoolDatasetCreate,
VRTAddSimpleSource (is there a simpler way?)
- create base layer tiles from virtual dataset; use
GDALDataset::RasterIO()
- create tiles higher in the pyramid (gdal2tiles.py) from existing ones
Any advice / idea / pointers to higher level functions that do some of the
work is highly appreciated.
Thanks,
Nick
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140821/f01c5471/attachment.html>
