[gdal-dev] why gdaldem is not working?
Cleo Drakos cleo21drakos at gmail.com
Fri Aug 22 20:53:16 PDT 2014
I have a geotiff file with class values (0, 1,  2, 3, and 4).
I want to show each class as different rgb color.
So, I created the text file (color_relief.txt) which contans the following:
0 55 78 94
1 98 23 64
2 112 35 99
3 34 67 72
4 78 250 60
Then I run the following code using python:
import subprocess
in_file =  'single_band.tif'
text_file = 'color_relief.txt'
gdaldem = 'C:\\Python27\\Lib\\site-packages\\osgeo\\gdaldem.exe'
out_file =  'result.tif'
subprocess.call([gdaldem
,'color-relif',in_file,text_file,out_file,'-exact_color_entry','-b','1'],shell=True)
in_file, out_file = None, None
Unfortunately, no result file is obtained.
What is wrong with my code?
cleo
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140823/629be00d/attachment.html>
