[gdal-dev] Converting MDB File With Unicode Characters
Even Rouault
even.rouault at spatialys.com
Mon Aug 25 02:26:07 PDT 2014
Selon Tomer <tomerlieber at gmail.com>:
> Hey,
> I'm using C# wrapper of GDAL and I'm having a problem converting MDB file
> that contains unicode characters.
> Lets take for example conversion to KML file, non-English characters are
> replaced by '?'
Did you try with ogr2ogr first ? To check if the issue is in the ODBC driver (is
that the one that is used actually, since both the ODBC or Java-based MDB driver
could be used), or with the C# bindings, or with your code
> How do I solve it?
http://osgeo-org.1560.x6.nabble.com/Converting-MDB-File-With-Unicode-Characters-tp5158087.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
