[gdal-dev] Converting MDB File With Unicode Characters
Even Rouault even.rouault at spatialys.com
Tue Aug 26 00:45:36 PDT 2014
Selon Tomer <tomerlieber at gmail.com>:
> The ogrinfo display non-English characters as '?'. I'm not sure in which
> encoding it return its results. (Is there any way to check the encoding?)
For example, if you do "ogrinfo the_arguments > somefile.txt" and open it with
Notepad++, you can try different options in the Encoding menu to find which one
displays the file correctly.
> Example for ogrinfo output:
> OGRFeature<poly_mdb_23>:4
> OBJECTID <Integer> = 3
> ????_?? <String> = -?????
http://osgeo-org.1560.x6.nabble.com/Converting-MDB-File-With-Unicode-Characters-tp5158087p5158293.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
