[gdal-dev] Error when trying to compress a TIFF file
Even Rouault
even.rouault at spatialys.com
Tue Aug 26 07:25:24 PDT 2014
Hanlie,
The warning "VRTSourceRasterBand::iRatserIO() called recursively on the same
band" is bug http://trac.osgeo.org/gdal/ticket/5468
It is due to the statistics computation on the intermediate VRT file
(implementation detail), but shouldn't influence on the image itself
You can run afterward "gdalinfo -stats Test_8bit_JPEG_Compr.TIF" to compute
statistics on the result TIF.
The slowness in QGIS is not surprising since JPEG takes time to decompressing,
especially for big images, that are not tiled and have no overviews. What could
help is to add -co TILED=YES on the gdal_translate command line.
And then run "gdaladdo --config COMPRESS_OVERVIEW JPEG Test_8bit_JPEG_Compr.TIF
2 4 8 16" on the result to create overviews.
Even
> Hi,
> I'm trying to convert a 16 bit image to 8 bits and at the same time
> add JPEG compression, but gdal reports errors during the process.
> gdal_info for the input file is:
> Driver: GTiff/GeoTIFF
> Files: D:/SPOT 6/PS_Envi/Test_8bit.TIF
> Size is 30717, 28629
> Coordinate System is:
> PROJCS["WGS 84 / UTM zone 34S",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",21],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",10000000],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","32734"]]
> Origin = (537234.000000000000000,6296730.000000000000000)
> Pixel Size = (1.500000000000000,-1.500000000000000)
> Metadata:
> AREA_OR_POINT=Area
> Band_1=CN Sharp R (Band
> 3:IMG_SPOT6_MS_201304220815274_ORT_742338101_R1C1.TIF)
> Band_2=CN Sharp G (Band
> 2:IMG_SPOT6_MS_201304220815274_ORT_742338101_R1C1.TIF)
> Band_3=CN Sharp B (Band
> 1:IMG_SPOT6_MS_201304220815274_ORT_742338101_R1C1.TIF)
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 537234.000, 6296730.000) ( 21d24' 2.56"E, 33d28' 5.67"S)
> Lower Left ( 537234.000, 6253786.500) ( 21d24' 9.04"E, 33d51'20.01"S)
> Upper Right ( 583309.500, 6296730.000) ( 21d53'47.54"E, 33d27'56.33"S)
> Lower Right ( 583309.500, 6253786.500) ( 21d54' 2.03"E, 33d51'10.53"S)
> Center ( 560271.750, 6275258.250) ( 21d39' 0.30"E, 33d39'39.04"S)
> Band 1 Block=30717x1 Type=Byte, ColorInterp=Red
> Description = CN Sharp R (Band
> Band 2 Block=30717x1 Type=Byte, ColorInterp=Green
> Description = CN Sharp G (Band
> Band 3 Block=30717x1 Type=Byte, ColorInterp=Blue
> Description = CN Sharp B (Band
> The command I'm using is:
> gdal_translate -ot Byte -of GTiff -scale 0 4905 0 255 -stats -co
> COMPRESS=JPEG "D:/SPOT 6/PS_Envi/Test.TIF" "D:/SPOT
> 6/PS_Envi/Test_8bit_JPEG_Compr.TIF"
> The last part of the error message is:
> ERROR 1: IReadBlock failed at X offset 18, Y offset 2
> ERROR 1: VRTSourceRasterBand::iRatserIO() called recursively on the
> same band. It looks like the VRT is referencing itself.
> ERROR 1: IReadBlock failed at X offset 19, Y offset 2
> More than 1000 errors or warnings have been reported. No more will be
> reported from now.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> gdal_translate does complete the process and I get an output file that
> looks usable, but I think something is wrong with the file because
> working with it in QGIS takes longer than the original image, which is
> two orders of magnitude bigger in file size.
> gdal_info for the output file is:
> Files: D:/SPOT 6/PS_Envi/Test_8bit_JPEG_Compr.TIF
> D:/SPOT 6/PS_Envi/Test_8bit_JPEG_Compr.TIF.aux.xml
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> UNIT["metre",1,
> Metadata:
> AREA_OR_POINT=Area
> COMPRESSION=JPEG
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Band 1 Block=30717x16 Type=Byte, ColorInterp=Red
> Band 2 Block=30717x16 Type=Byte, ColorInterp=Green
> Band 3 Block=30717x16 Type=Byte, ColorInterp=Blue
> Does anybody perhaps know what is going wrong or can suggest another
> method to accomplishing what I wish to?
> I have successfully created an 8 bit image without using compression,
> so I'm pretty sure the error stems from the compression operation.
> Regards
> Hanlie
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
