[gdal-dev] Converting MDB File With Unicode Characters
Even Rouault
even.rouault at spatialys.com
Wed Aug 27 00:46:34 PDT 2014
Le mardi 26 août 2014 12:33:49, Tomer a écrit :
> i tried different options in the Encoding menu but none displayed the file
> correctly. I think the problem is caused by incorrect reading of the mdb
> file made by the driver.
You could open a ticket in Trac (see "Submit a new bug report" on
http://trac.osgeo.org/gdal/wiki) with a sample mdb attached (attachment size
is limited, so potentially just an extract of it that demonstrate the issue)
> http://osgeo-org.1560.x6.nabble.com/Converting-MDB-File-With-Unicode-Chara
> cters-tp5158087p5158338.html Sent from the GDAL - Dev mailing list archive
> at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
