[gdal-dev] SVG support
Kyle Shannon kyle at pobox.com
Fri Aug 29 08:40:31 PDT 2014
Scott,
On Fri, Aug 29, 2014 at 9:25 AM, Scott Rowles <scott_rowles at hotmail.com> wrote:
> Hi,
> I am using the 1.11 precompiled binaries with with libexpat included in the
> GDAL_DATA path.  I am trying to read an SVG file, which according to the
> vector format support table should work.  But it is failing and saying that
> it cannot open the file.
The svg driver appears to be very limited:
http://gdal.org/drv_svg.html
Currently, it will only read SVG files that are the output from
Cloudmade Vector Stream Server
> Any thoughts on how to troubleshoot/resolve this?
> scott
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Kyle
