[gdal-dev] Problem encountered in stitching/merging the raster files
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Aug 29 09:36:17 PDT 2014
user_name <ljvillarin30 <at> gmail.com> writes:
> I've tried your suggestion but then the result was this:
> Note: I used OpenEV to open the file.
> <http://osgeo-org.1560.x6.nabble.com/file/n5158992/openev.gif>
Result looks like it is because the black slivers which are created by
warping are not made transparent. Have a try by adding -dstnodata 0 0 0 to
the gdalwarp command.
-Jukka Rahkonen-
