[gdal-dev] Problem using gdalbuildvrt with a large number of source datasets
Homme Zwaagstra hrz at geodata.soton.ac.uk
Wed Dec 3 02:24:22 PST 2014
Hello Jukka,
On 03/12/14 10:13, Jukka Rahkonen wrote:
> Homme Zwaagstra <hrz  <at> geodata.soton.ac.uk> writes:
 >> Hello,
 >> I've come up against a problem with `gdalbuildvrt` taking a long
time to
 >> create
 >> a VRT when it is passed a large number of source datasets. I am trying
 >> to create
 >> a VRT file for a zoom level in a TMS structure containing JPEG
tiles.  The
 >> command I'm using is:
 >> gdalbuildvrt output.vrt `find ./tiles/18 -iname *.jpg -printf "%p "`
 >> where the number of tiles is:
 >> $ find ./tiles/18 -iname *.jpg | wc -l
 >> 767104
 > I would say that you are doing all wrong thing. First, the jpeg tiles in
 > tile service directory structure are not referenced with world files
(.jgw)
 > or anything and your .vrt file would be useless.
Sorry, I should have said: each of the JPEG tiles has an accompanying
`*.aux.xml` file.  The files were created under the hood by GDAL using
<https://github.com/geo-data/cesium-terrain-builder#ctb-tile>.
> The right thing to do is to  study the file naming schema that the cache is
 > using. When the schema is known the right tile can be found directly
because
 > the logic knows how the tile directory structure is like and which
names are
 > used for the tiles. If it is an OSGeo TMS schema it is described here
http://wiki.osgeo.org/wiki/Tile_Map_Service_Specification#TileMapService_Resource
The on-disk tiling scheme conforms to
<http://wiki.osgeo.org/wiki/Tile_Map_Service_Specification#global-mercator>
with
the tile directory structure matching `{zoom}/{x}/{y}.jpg`.
Best regards,
Homme
 > If it is using the Google/Bing tile naming schema then you can find
examples
 > here http://www.gdal.org/frmt_wms.html. But if it is a GeoWebCache tile
 > cache you may be out of luck because I haven't seen so far any
configuration
 > file that would make GWC tilecache usable for GDAL.
 > -Jukka Rahkonen-
 > gdal-dev mailing list
 > gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141203/51dedad7/attachment.html>
