[gdal-dev] Using ogrinfo and ogr2ogr Behind Proxy
Langford, Robert Robert.Langford at salford.gov.uk
Wed Dec 3 05:19:29 PST 2014
Even,
Thanks, was trying to set on the command line, but managed to set as variable first.  All working now.
Rob
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: 03 December 2014 13:10
To: gdal-dev at lists.osgeo.org
Cc: Langford, Robert
Subject: Re: [gdal-dev] Using ogrinfo and ogr2ogr Behind Proxy
Le mercredi 03 décembre 2014 13:57:05, Langford, Robert a écrit :
> All,
> I'm wondering how I can access a WFS with ogrinfo and ogr2ogr from
> behind my proxy at work.
> I've searched on Google and have found reference to
> "GDAL_HTTP_PROXY=host:port" and "GDAL_HTTP_PROXYUSERPWD=user:pass"
> But I'm not sure how I'd use them from the CLI?
Rob,
See http://trac.osgeo.org/gdal/wiki/ConfigOptions
Even
Spatialys - Geospatial professional services http://www.spatialys.com
DISCLAIMER: The information contained in this communication/message from Robert.Langford at salford.gov.uk sent on Wed Dec  3 13:19:31 2014 is confidential. It is intended solely for the addressee(s) gdal-dev at lists.osgeo.org;even.rouault at spatialys.com
Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.
As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.
Please immediately contact the sender, Robert.Langford at salford.gov.uk if you have received this message in error.
For the full disclaimer please access http://www.salford.gov.uk/e-mail.  Thank you.
