[gdal-dev] OGR support for Google Latitude KML output
Even Rouault even.rouault at spatialys.com
Thu Dec 4 08:07:45 PST 2014
Le mercredi 03 décembre 2014 19:53:44, Ulrich Strötz a écrit :
> Hi everyone,
> I am trying to use ogr2ogr with a KML file generated by Google My Tracks
> <https://play.google.com/store/apps/details?id=com.google.android.maps.myt
> racks&hl=en>.
> There was a ticket #5095 <http://trac.osgeo.org/gdal/ticket/5095> about
> this which is marked as fixed, but it still does not work properly.
> I use GDAL 1.11.1, released 2014/09/24 and the following command:
> ogr2ogr -f "GeoJSON" out.geojson in.kml
> It does create only the start and end points of the track, but not the
> points in between.
> The sample file can be found here.
> https://www.dropbox.com/s/ilafup4m0vcvmxj/in.kml?dl=0
> <https://www.dropbox.com/s/ilafup4m0vcvmxj/in.kml?dl=0>
> Any help on how to get this to work is appreciated.
Ulrich,
Ticket 5095 was about gx:Track, but the geometry in your file is a
gx:MultiTrack. I've just added support for the later in the LIBKML driver in
GDAL trunk.
Even
http://www.spatialys.com
