[gdal-dev] Garmin .img data?
Even Rouault
even.rouault at spatialys.com
Fri Dec 19 08:01:48 PST 2014
Hi Paolo,
> Hi all.
> AFAIK the format is not supported in GDAL, whereas it is so by smaller
> GPL projects:
> https://bitbucket.org/maproom/qmapshack/wiki/Home
> Any special reason we do not have that support?
Probably perhaps nobody has written it. The link you gave doesn't link much
information about the format.
Is it the vector format described at http://sourceforge.net/projects/garmin-
img/?source=typ_redirect ?
If so, a quick skimming of it would lend me thinking that read support should
be possible, although likely not a trivial effort (41 pages for an unformal
specification is quite significant). Write support and interoperability with
Garmin devices would probably be harder as I can see quite a few ??? in the
document.
Even
http://www.spatialys.com
