[gdal-dev] Garmin .img data?
Andre Joost
andre+joost at nurfuerspam.de
Fri Dec 19 09:40:13 PST 2014
Am 19.12.2014 um 17:39 schrieb Paolo Cavallini:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Even,
> Il 19/12/2014 17:01, Even Rouault ha scritto:
>> Probably perhaps nobody has written it. The link you gave doesn't
>> link much information about the format. Is it the vector format
>> described at http://sourceforge.net/projects/garmin-
>> img/?source=typ_redirect ? If so, a quick skimming of it would lend
>> me thinking that read support should be possible, although likely
>> not a trivial effort (41 pages for an unformal specification is
>> quite significant). Write support and interoperability with Garmin
>> devices would probably be harder as I can see quite a few ??? in
>> the document.
> thanks for your reply. I imagined this, but I was surprised by the
> fact that apparently small projects were able to read the format
> without much difficulty.
> Going to ask qmapshack dev.
Just for the record:
The Garmin img format has been inofficially reverse engineered, and used
to create own maps. This page gives an overview of the software that is
used to make Garmin maps from OSM data:
http://wiki.openstreetmap.org/wiki/OSM_Map_On_Garmin#Software
Greetings,
André Joost
