[gdal-dev] Can't make GME driver work
Wolf Bergenheim
wolf+grass at bergenheim.net
Sat Dec 20 06:26:52 PST 2014
Cool! Thanks for the feedback. I'll update the wiki page :)
--Wolf on Android
The usual disclaimer goes here
On 20 Dec 2014 12:25, "Jorge Arévalo" <jorge at cartodb.com> wrote:
> Hi Wolf
> I already fixed it. I had to follow these steps:
> - Define GOA2_CLIENT_ID, GOA2_CLIENT_SECRET, GME_APIKEY
> - Define GME_REFRESH_TOKEN, which allow the app to refresh the token
> No problem, so far. Just followed this
> http://trac.osgeo.org/gdal/wiki/GMEDriver
> - Define GME_AUTH (or provide 'auth' in the query string). This is not
> specified in the wiki page, but can be found here:
> https://github.com/OSGeo/gdal/blob/trunk/gdal/ogr/ogrsf_frmts/gme/ogrgmedatasource.cpp#L140
> The steps to get those environment vars are:
> - GOA2_CLIENT_ID, GOA2_CLIENT_SECRET, GME_APIKEY --> from Google API
> console
> - GME_AUTH, GME_REFRESH_TOKEN --> execute gdal_auth.py. Also stated in the
> wiki page. Just use the interactive option.
> gdal_auth.py -s gme
> So, the wiki page is basically correct. But just need to add the part
> about GME_AUTH :-)
> Best regards,
> Jorge
> El 19/12/2014 18:33, "Wolf Bergenheim" <wolf+grass at bergenheim.net>
> escribió:
>> Hi Jorge.
>> I noticed some issues with it earlier this week. I'll see if I have some
>> spare time over the weekend to see what I can do about it. Are you using
>> the trunk version or an earlier release?
>> On 18 December 2014 at 23:23, Jorge Arévalo <jorge at cartodb.com> wrote:
>>> Hello,
>>> I'm having problems making the GDAL GME driver work (
>>> http://trac.osgeo.org/gdal/wiki/GMEDriver). I've defined CLIENT_API and
>>> CLIENT_SECRET in Google API console, and I successfully used them with the
>>> QGIS GME plugin (
>>> https://plugins.qgis.org/plugins/GoogleMapsEngineConnector/) and with
>>> the example Python script of the doc page:
>>> https://developers.google.com/maps-engine/documentation/oauth/installedapplication.
>>> But, for some reason, I keep getting HTTP 401 error when trying to read
>>> from my GME account using the GDAL driver.
>>> I've used gdal_auth.py to get the access token and the refresh token.
>>> Passed the config options, as stated in the driver's page. Always getting
>>> HTTP 401.
>>> Do you have any working example using GDAL GME driver? More info about
>>> my problem here:
>>> http://gis.stackexchange.com/questions/127065/i-cant-configure-authentication-with-google-maps-engine-driver-from-gdal
>>> Many thanks in advance!
>>> Jorge
>>> Sent using Postbox:
>>> http://www.getpostbox.com
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141220/29565d92/attachment.html>
