[gdal-dev] gdalwarp reporjection issue
Even Rouault
even.rouault at spatialys.com
Wed Dec 24 02:36:31 PST 2014
Bin Zhao,
Problem reproduced, identified and fixed per
http://trac.osgeo.org/gdal/ticket/5789
You can use two workarounds :
- remove "-wm 500"
- use a target extent that matches more closely the original bounds. For
example -te -180 -90 180 -45
Both will avoid coordinates that are very far from the south pole (e.g. in the
northern hemisphere) to be reprojected to non-sense values, which triggered
the bug.
Best regards,
Even
Le mardi 23 décembre 2014 21:56:15, Bin Zhao a écrit :
> Hi,
> First time gdal user here.
> I am trying to use gdalwarp to reproject a raster file from polar stereo
> to WGS84. The original raster has nodata value 127 and 0's and 1's as
> real data values. After warping, the file contains only nodata values,
> i.e., all real data got lost. Could anyone help me with it.
> The data comes from
> https://secure.antarctica.ac.uk/data/bedmap2/bedmap2_tiff.zip
> The raster file is bedmap2_icemask_grounded_and_shelves.tif from that
> zip file.
> gdalinfo --version
> GDAL 1.10.0, released 2013/04/24
> I am using the command line below
> gdalwarp --config GDAL_CACHEMAX 500 -wm 500 -t_srs EPSG:4326 -te -180
> -90 180 90 -multi -srcnodata 127 -dstnodata 127
> bedmap2_icemask_grounded_and_shelves_reproj.tif
> Some information for the original raster:
> gdalinfo -stats bedmap2_icemask_grounded_and_shelves.tif
> Driver: GTiff/GeoTIFF
> Files: bedmap2_icemask_grounded_and_shelves.tif
> bedmap2_icemask_grounded_and_shelves.tif.ovr
> bedmap2_icemask_grounded_and_shelves.tfw
> bedmap2_icemask_grounded_and_shelves.tif.aux.xml
> Size is 6667, 6667
> Coordinate System is:
> PROJCS["WGS_1984_Stereographic_South_Pole",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["Polar_Stereographic"],
> PARAMETER["latitude_of_origin",-71],
> PARAMETER["central_meridian",0],
> PARAMETER["scale_factor",1],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]]]
> Origin = (-3333500.000000000000000,3333500.000000000000000)
> Pixel Size = (1000.000000000000000,-1000.000000000000000)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left (-3333500.000, 3333500.000) ( 45d 0' 0.00"W, 48d27'31.20"S)
> Lower Left (-3333500.000,-3333500.000) (135d 0' 0.00"W, 48d27'31.20"S)
> Upper Right ( 3333500.000, 3333500.000) ( 45d 0' 0.00"E, 48d27'31.20"S)
> Lower Right ( 3333500.000,-3333500.000) (135d 0' 0.00"E, 48d27'31.20"S)
> Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 90d 0' 0.00"S)
> Band 1 Block=128x128 Type=Byte, ColorInterp=Gray
> Min=0.000 Max=1.000
> Minimum=0.000, Maximum=1.000, Mean=0.112, StdDev=0.315
> NoData Value=127
> Overviews: 3334x3334, 1667x1667, 834x834, 417x417, 209x209
> Metadata:
> STATISTICS_MAXIMUM=1
> STATISTICS_MEAN=0.11176160412634
> STATISTICS_MINIMUM=0
> STATISTICS_STDDEV=0.31507293640332
> PIXELTYPE=SIGNEDBYTE
> <GDALRasterAttributeTable>
> <FieldDefn index="0">
> <Name>OBJECTID</Name>
> <Type>0</Type>
> <Usage>0</Usage>
> </FieldDefn>
> <FieldDefn index="1">
> <Name>Value</Name>
> <Type>0</Type>
> <Usage>0</Usage>
> </FieldDefn>
> <FieldDefn index="2">
> <Name>Count</Name>
> <Type>1</Type>
> <Usage>0</Usage>
> </FieldDefn>
> <Row index="0">
> <F>1</F>
> <F>0</F>
> <F>12104872</F>
> </Row>
> <Row index="1">
> <F>2</F>
> <F>1</F>
> <F>1523082</F>
> </Row>
> </GDALRasterAttributeTable>
> Thanks,
> Bin Zhao
http://www.spatialys.com
