[gdal-dev] What is the maximum '-wm' I can use with 64bit gdalwarp?
Even Rouault even.rouault at spatialys.com
Fri Dec 26 03:27:52 PST 2014
Le vendredi 26 décembre 2014 07:03:41, Simen Langseth a écrit :
> Dear Even Rouault
> Whether I use '-multi' or not, '-wm 1024' works, but '-wm 3024' does not
> work in my PC.
You don't give enough details so that we can understand what "does not work".
See http://lists.osgeo.org/pipermail/gdal-dev/2014-December/040706.html as an
example how to do a good report.
In theory, specifying big values of -wm can :
- fail if the process cannot allocate the memory
- or increase speed
- or decrease speed
- or have no impact
It shouldn't alter the result, ideally. But there are complex situations where
bigger chunks cause coordinate transformations to be more problematic for the
warper, as the bug I mentionned in my previous message.
http://www.spatialys.com
