[gdal-dev] Is user document about gdalwarp still good?
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Fri Dec 26 06:09:23 PST 2014
Even Rouault <even.rouault <at> spatialys.com> writes:
> Le vendredi 26 décembre 2014 12:09:29, Jukka Rahkonen a écrit :
> > Hi,
> > There is a user document about gdalwarp in the wiki
> > http://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp. However, it is a bit old
> > with references to GDAL 1.7.2. I would like to add a link to this document
> > into gdalwarp manual page http://www.gdal.org/gdalwarp.html but I wonder if
> > there is something to update in the wiki document first.
> > It would be nice is gdalwarp specialists could check the wiki doc and
> > comment if it contains some outdated information.
> Was mostly good. I've done some small updates.
> Some behaviours slightly change/improve between versions.
Thanks. I have to say that after browsing the sources for a good while I
have still no idea what to edit for adding section "See also" and a link to
the wiki document to gdalwarp utility page http://www.gdal.org/gdalwarp.html.
-Jukka-
