[gdal-dev] Buffering Right and Buffering Left Using Gdal/OGR
Ari Jolma
ari.jolma at gmail.com
Tue Dec 30 02:40:47 PST 2014
Dear Pratap,
You're really using GEOS with GDAL just as a middleware, so perhaps
you'd better try GEOS or PostGIS lists. I don't think there is a simple
solution to this problem, you might try perhaps to extend the line and
make a polygon out of it and then do an intersection with the buffer(?).
Best regards,
Ari
29.12.2014, 08:12, Pratap Chelamilla kirjoitti:
> /Hi,
> /I am trying to buffer polyline to its right / left , Is there any way
> to buffer right/left using GDAL/OGR.
> OGRGeometry*bufGeometry=geometry->Buffer(buffer);/
> /I have tried providing buffer value with positive and negative, but
> unable to see any buffering around the polyline.Please provide
> us solution to solve this problem./
> Regards,
> Pratap.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141230/20ee6b68/attachment.html>
