[gdal-dev] warnings a fail with poppler
Joaquim Luis
jluis at ualg.pt
Sat Feb 1 17:05:23 PST 2014
I am seeing this warnings and trying to build with poppler (a trunk
build here) fails too with
pdfdataset.obj : error LNK2001: unresolved external symbol "public:
__cdecl SplashOutputDev::SplashOutputDev(enum
SplashColorMode,int,bool,unsigned char *,bool,bool,enum
SplashThinLineMode,bool)"
(??0SplashOutputDev@@QEAA at W4SplashColorMode@@H_NPEAE11W4SplashThinLineMode@@1 at Z)
struct Ref * __cdecl Catalog::getPageRef(int)"
(?getPageRef at Catalog@@QEAAPEAURef@@H at Z)
I could see that SplashOutputDev is poppler.lib
and now the warnings
c:\programs\gdaltrunk\gdal\frmts\iris\irisdataset.cpp(564) : warning
C4701: potentially uninitialized local variable 'dfCos2SigmaM' used
c:\programs\gdaltrunk\gdal\frmts\iris\irisdataset.cpp(558) : warning
C4701: potentially uninitialized local variable 'dfSinSigma' used
C4701: potentially uninitialized local variable 'dfCosSigma' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf4imagedataset.cpp(2469) :
warning C4701: potentially uninitialized local variable 'iWrkNumType' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf4imagedataset.cpp(3440) :
warning C4706: assignment within conditional expression
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf4imagedataset.cpp(3447) :
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf4imagedataset.cpp(3462) :
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf4imagedataset.cpp(3469) :
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf4imagedataset.cpp(3401) :
warning C4701: potentially uninitialized local variable 'dfNoData' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf4imagedataset.cpp(3405) :
warning C4701: potentially uninitialized local variable 'dfScale' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf4imagedataset.cpp(3410) :
warning C4701: potentially uninitialized local variable 'dfOffset' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\ehapi.c(448) : warning
C4701: potentially uninitialized local variable 'sdInterfaceID' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\ehapi.c(435) : warning
C4701: potentially uninitialized local variable 'HDFfid' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\ehapi.c(445) : warning
C4701: potentially uninitialized local variable 'acs' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(3270) : warning
C4701: potentially uninitialized local variable 'c_info' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(3281) : warning
C4701: potentially uninitialized local variable 'chunkDef' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(6470) : warning
C4701: potentially uninitialized local variable 'latrad0' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(6500) : warning
C4701: potentially uninitialized local variable 'yMtr0' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(6499) : warning
C4701: potentially uninitialized local variable 'xMtr0' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(2632) : warning
C4701: potentially uninitialized local variable 'ndims' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(6741) : warning
C4701: potentially uninitialized local variable 'qp_cea' used
C4701: potentially uninitialized local variable 'kz_cea' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(7967) : warning
C4701: potentially uninitialized local variable 'minCol' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(7969) : warning
C4701: potentially uninitialized local variable 'minRow' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(7968) : warning
C4701: potentially uninitialized local variable 'maxCol' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(7970) : warning
C4701: potentially uninitialized local variable 'maxRow' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(8614) : warning
C4701: potentially uninitialized local variable 'rank' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(9025) : warning
C4701: potentially uninitialized local variable 'j' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(9564) : warning
C4701: potentially uninitialized local variable 'xdum' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(9565) : warning
C4701: potentially uninitialized local variable 'ydum' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(9681) : warning
C4701: potentially uninitialized local variable 'size' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(9843) : warning
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(9844) : warning
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(10109) : warning
C4701: potentially uninitialized local variable 'nRetn' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\gdapi.c(10573) : warning
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(2451) : warning
C4701: potentially uninitialized local variable 'vdataID' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(4282) : warning
C4701: potentially uninitialized local variable 'nVal' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(5839) : warning
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(6454) : warning
C4701: potentially uninitialized local variable 'tmpVal' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(6776) : warning
C4701: potentially uninitialized local variable 'k' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(7267) : warning
C4701: potentially uninitialized local variable 'incr' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(7301) : warning
C4701: potentially uninitialized local variable 'offset' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(7271) : warning
C4701: potentially uninitialized local variable 'index' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(7249) : warning
C4701: potentially uninitialized local variable 'bufOffset' used
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(8428) : warning
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(8414) : warning
c:\programs\gdaltrunk\gdal\frmts\hdf4\hdf-eos\swapi.c(9128) : warning
