[gdal-dev] Fast Pixel Access
Luke Roth roth.luke at gmail.com
Mon Feb 3 06:10:38 PST 2014
Another thing that might speed up access is setting the config option
GDAL_DISABLE_READDIR_ON_OPEN
= TRUE, either as an environment variable or on the command line.  That
should help with GDAL reading the directory each time it opens a dataset.
 I have an application which reads one value from each of a large number of
datasets and setting this option made it run about 3 times faster.
Luke
On Sun, Feb 2, 2014 at 2:12 PM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>wrote:
> Hi,
> I made a few tests and here comes my conclusions. Hypothesis is that
> someone
> wants to make a DEM query service which is using gdallocationinfo for
> queries and DEM data is to be accessed as files from a standard web site. I
> compared three alternatives:
> 1) There are thousands of DEM files on the server and they are combined
> together with a VRT file.
> 2) There is only one DEM file as BigTIFF.
> 3) DEM is split into tiles into x/y/z tile directory structure like in
> Google maps or OpenStreetMap tiles.
> My test data covers Finland with 10 m grid size and as deflate compressed
> tiffs they make about 10 GB together.
> Before going on, keep in mind that the speed needs indexes. The better
> index, the less unnecessary data to read. In case 1) the first level index
> is the VRT file. The second level index, if it exists, is in the headers of
> the real DEM files. It may be possible to jump to a correct offset from the
> beginning of the DEM data and read only a part of the file.  In case 2) the
> index is in the internal TIFF directory. If the BigTIFF is tiled the access
> to tiles should be rather effectice. And finally in case 3) the index is
> built into directory structure and tiling schema that is used for saving
> the
> tiles. The schema is no well known that tile map service clients can
> directly ask for a certain file name if they know the coordinates and
> scale.
> Conclusions:
> 1)
> - The whole VRT file must be readed. Caching the vrt file would make next
> requests faster.
> - For some reason gdallocationinfo wants to get the directory list of the
> directory where the vrt file is. This is slow and generates lots of traffic
> if the thousands of DEM files are in the same directory. Probably it would
> be faster to have them in another dierectory.
> 2)
> - BigTIFF route is more straight forward but gdallocationinfo needs still
> to
> do many big range reads.
> - Also in this case gdallocationinfo reads the target file directory. It
> would be good to keep this directory small. Don't do like I did with having
> in the directory the BigTIFF DEM file that was the only file needed, but
> also the vrt and thousands of original DEMs from the previuos test -> but
> at
> least this is a know this issue now and know how to avoid it. In my case
> reading the directory made 2.2 MB of web traffic and all or most for wain.
> 3)
> - I used OpenStreetMap tile service as the test data for the third test. In
> this case gdallocationinfo knows exactly which tile to request and it is
> making only one request. It also seems to cache some tiles on the client
> side which means that queries for close locations may hit the cached tile
> and be very fast.
> Summary statistics:
> 1) Gdallocationinfo makes 6 requests and reads 6.4 MB of data
> 2) Gdallocationinfo makes 8 requests and reads 4.3 MB of data
> 3) Gdallocationinfo makes 1 requests and reads 10 kB of data
> Requests I used are these:
> 1)
> gdallocationinfo /vsicurl/http://latuviitta.kapsi.fi/data/
> dem10m/dem_10m.vrt -geoloc  389559 6677412
> 2)
> dem10m/dem_10m.tif -geoloc  389559 6677412
> 3)
> gdallocationinfo  frmt_wms_openstreetmap_tms.xml -geoloc  389559 6677412
> I know that the queried place in 3) is not the same because SRIDs of data
> differ nor does OSM return 16-bit DEM heights but 3-band RGB values instead
> but it does not matter here, the idea is what is important.
> My conclusion is that you should cut your DEM into tiles with for example
> gdal2tiles or MapTiler and the resuld could actually be quit speedy and
> perhaps using 126x126 tiles could make it still a bit faster. Hope that
> they
> can create tiles as 16-bit tiffs.
>  I am sure that these results are not scientifically sound but I am also
> sure that the difference between 6.4 MB/4.3 MB/10 kB is something to think
> about especially if you dream about a mobile service.
> I placed the requests which gdallocationinfo made during these tests into
> http://latuviitta.org/documents/gdallocationinfo_requests.txt
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140203/44594a89/attachment.html>
